Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: Generated ground broken on import, regenerate? » » » » Post: Re: Generated ground broken on import, regenerate? |
Print at Oct 13, 2026, 1:42:09 AM |
| Posted by Puybaret at Apr 5, 2024, 6:03:25 PM |
Re: Generated ground broken on import, regenerate? I fear it's rather an issue in the way Sweet Home 3D attempts to cut the ground with the room. Sometimes it doesn't work well. I tried so many times to fix this problem, that I'm not sure there's a better solution. Maybe moving a little the corners of the room where you see the issue could help. Anyway, no need to export many times your design to check a fix, because you should see this flickering in Sweet Home 3D too. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Oct 13, 2026, 1:42:09 AM |
