Print at Oct 12, 2026, 11:13:03 AM
Posted by leonidas_o at Apr 5, 2024, 10:27:17 PM
Re: Generated ground broken on import, regenerate?
@Keet hmm that's strange, I can see the images even when looking up this post on my smartphone.
Yes, your assumption is correct. I was using "export all". I've tried that, select all and export selected, this works, as the "cut-out-ground" is then not exported.
@Puybaret, I've tried to move corners, whole rooms, walls, change wall width etc. Nothing helped here, so right now I've exported all selected. I can live with that approach, the only thing is, I have to create a ground plane, as I mostly created square rooms, which means, there is no floor in between door frames. So I can see through it atm.
So what is the difference between, "export all" and select all and "export selected"? Is only the one cut-out-ground plane?
