Sweet Home 3D Forum » List all forums » » Forum: Installation » » » Thread: Import content from portable version » » » » Post: Re: Import content from portable version |
Print at Sep 23, 2026, 6:40:21 PM |
| Posted by Puybaret at Apr 11, 2024, 7:20:15 PM |
Re: Import content from portable version The content of the data folder found in the portable version is compatible with the following folder of the installer version: - under Windows Vista / 7 / 8 / 10 /11, the folder C:\Users\user\AppData\Roaming\eTeks\Sweet Home 3D, - under Windows XP, the folder C:\Documents and Settings\user\Application Data\eTeks\Sweet Home 3D, - under Mac OS X with the free version, the subfolder Library/Application Support/eTeks/Sweet Home 3D of your user folder, - under Mac OS X with the Mac App Store version, the subfolder Library/Containers/com.eteks.sweethome3d.SweetHome3D/Data/Library/Application Support/eTeks/Sweet Home 3D of your user folder, - under Linux and other Unix, the subfolder .eteks/sweethome3d of your user folder. Just quit Sweet Home 3D, copy the content of data folder to the matching folder (mostly furniture and textures folders, as well as preferences.xml and .pref files) and relaunch the program. Then you should find back all the 3D models and textures you imported in Sweet Home 3D portable version. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 23, 2026, 6:40:21 PM |
