Sweet Home 3D Forum » List all forums » » Forum: New versions » » » Thread: Sweet Home 3D 2.4 » » » » Post: Re: Sweet Home 3D 2.4 |
Print at Sep 23, 2026, 4:59:27 AM |
| Posted by db4tech at May 30, 2010, 12:53:48 AM |
Re: Sweet Home 3D 2.4 When I conducted my original tests, I did try enlarging the interface without using the maximize button, to see if the window positions stayed constant, which they do, the only problem is, it is very easy to forget when switching applications, if instead of minimizing Sweet Home, I just move the interface window slightly off screen (so some of the desktop is available) then on returning to use Sweet Home, without thinking double click anywhere the title bar which is my preferred method to maximize an application. I can understand you not wanting to get too technical, so keeping it simple, which is prefect for me! With the windows positions creeping (or changing) I'm guessing their current horizontal and vertical positions aren't defined by a percentage calculation when the interface is maximized? As that figure would never change no mater what the users screen resolution or aspect ratio.Thank you for your reply and offering a workaround. db4tech |
Current timezone is GMT Sep 23, 2026, 4:59:27 AM |
