Print at Sep 24, 2026, 2:19:28 PM
Posted by Daniels118 at Apr 12, 2024, 3:51:41 PM
Re: Generate PDF file.
Are you REALLY sure that labels aren't painted? It could be that in PDF they are drawn by default using transparent background, so the text cannot be seen. Try to select the text in the exported PDF, if the labels are there, then you should see the text highlighted.
If this is so, then you could simply set the background color; if background color isn't an available feature, just draw a rectangle before drawing the text.
Just courious: why in the world are these variables called this way?
Have you used a decompiler to get the source code? You should know that this is an open source software, so you can get the original sources.
