Sweet Home 3D Forum » List all forums » » Forum: Developers » » » Thread: Generate PDF file. » » » » Post: Re: Generate PDF file. |
Print at Sep 23, 2026, 7:45:04 PM |
| Posted by Puybaret at Apr 15, 2024, 11:23:44 AM |
Re: Generate PDF file. First thing, if you want some help, you have to help programmers understanding your code too. Naming every variable varsomething is really troublesome and in the long term, it won't help your code maintenance. Some comments could be welcomed too, at least to show where you made some modifications. Then, in your code: if (home.wallType.contains(var18.getModeCreationName())) {Did you try to print, instead of printing to PDF? Then, try to print through a PDF printer driver? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 23, 2026, 7:45:04 PM |
