Sweet Home 3D Forum » List all forums » » Forum: 3D models and textures » » » Thread: Custom 3D Model being imported without texture » » » » Post: Re: Custom 3D Model being imported without texture |
Print at Sep 29, 2026, 5:07:14 PM |
| Posted by [email protected] at Apr 17, 2024, 9:33:39 PM |
Re: Custom 3D Model being imported without texture As always, thanks Keet. I will try to do as you suggested. The import with those modes was intentional... I discovered the mode BY CANCEL while exporting for my test the old object in the HATCH+INVISIBLE library to only make indentations in the walls... (I was preparing an electrical system (without the plugin) and I needed to physically make tracks in the walls in which to place the pipes on one level, the wires on another and the walls on another in order to view them simultaneously or separately or view only the finished walls with the relative sockets, the junction boxes etc etc) when re-importing it I rotated it thus obtaining the possibility of sizing the trace without drilling the wall but it was only a trace without the possibility of limiting the window direction except by acting on rotations and dimensions, but it did it. on the contrary, this object does so regardless of the dimensions assigned and has TEXTUREABLE internal walls which allows it to also be made into a purely decorative element and at most a...FLUSH WALL PAINTING. |
Current timezone is GMT Sep 29, 2026, 5:07:14 PM |
