Sweet Home 3D Forum » List all forums » » Forum: Developers » » » Thread: SweetHome3DJS - Porting plugin - ARM architecture support » » » » Post: Re: SweetHome3DJS - Porting plugin - ARM architecture support |
Print at Sep 23, 2026, 7:39:23 PM |
| Posted by adizanni at May 5, 2024, 10:29:23 PM |
Re: SweetHome3DJS - Porting plugin - ARM architecture support Hello Emmanuel, not sure if there was an acknowledgment from your side of an issue with making your ServerUserPreferences library work behind a proxy. My last assessment was that, when working behind a proxy, if you pass to ServerUserPreferences constructor:
In my opinion it should be up to the JavaScript library to calculate the URL based on relative positioning of the resources. Do you acknowledge the problem ? Have you done any modification for v7.3 ? Not seen any reference about this problem in the release notes. |
Current timezone is GMT Sep 23, 2026, 7:39:23 PM |
