Sweet Home 3D Forum » List all forums » » Forum: Installation » » » Thread: SWH3D Frozen and unable to close it » » » » Post: Re: SWH3D Frozen and unable to close it |
Print at Sep 23, 2026, 10:37:58 PM |
| Posted by Keet at May 6, 2024, 3:11:59 PM |
Re: SWH3D Frozen and unable to close it I did try to install it from the website. However Zorin would not let me install. Said I must use the version they provide, in the software library. Strange. With new versions of Sweet Home 3D I don't install. I download the 64 bit .tgz file and extract it next to other versions I have. This can basically be anywhere you want. I have all versions on a separate partition for Sweet Home 3D on a data disk. Simple as that.Since the home .eteks folders are already there this should work just fine. Start with the SweetHome3D-Java3D-1_5_2 script in the extracted directory. This is on Debian. Ubuntu is based on Debian and Zorin is based on Ubuntu so this *should* work. If you have the memory available you can try to increase the amount of memory Sweet Home 3D is allowed to use by changing the -Xmx parameter in the startup script, for example to -Xmx4g or -Xmx6g. ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
Current timezone is GMT Sep 23, 2026, 10:37:58 PM |
