Print at Oct 4, 2026, 12:20:59 AM
Posted by sjb007 at May 9, 2024, 7:55:23 PM
Re: Wall pattern disappears in SVG when embedded in website
An alternative is to open your SVG file in Inkscape. Select the hashing image object(s) and delete it. Now select the wall outline, and use the Inkscape "pattern" fill feature on the actual wall outline. The outline and the fill are separate objects which makes this possible. You can select a pattern, rotate it and scale it, and I managed to get something pretty close to the hashing you used using one of the builtin options by doing this.
The Inkscape patterns are purely vector based, and will give you small file sizes.
