Print at Oct 14, 2026, 3:10:49 PM
Posted by silvanschaad at May 16, 2024, 3:22:23 PM
Re: View in separate window freezes my Mac
Thanks Emmanuel for your reply.
I did some more research on second screen behaviour and I looks like this is causing the wheel of death.
Fact is that a second monitor is crucial to have because on a 14" macbook I can't work for hours and don't have enough room for details nor overview.
So considering this I and your advice, the performance on the macbook without second screen was close to before. Mostly running without any issues no matter what I was doing.
I also changed the way I wired up the second monitor. Previously mostly with an external adapter, but now also with the direct html input. I couldn't see a mayor difference though...
What brought the solution for now (still testing and observing) is changing the lead monitor within system settings. I had chosen the macbook and changed now to the second monitor which basically solves the problem.
So prior to my old setup with an older intel-based macbook this seems to be a newer setting that you can make and that might cause these problems...
