Sweet Home 3D Forum » List all forums » » Forum: Gallery » » » Thread: Apartment project with lighting by invisible hemispheres. I continue advertising » » » » Post: Re: Apartment project with lighting by invisible hemispheres. I continue advertising |
Print at Oct 2, 2026, 12:31:14 PM |
| Posted by CinemaWalls at May 19, 2024, 11:05:32 AM |
Re: Apartment project with lighting by invisible hemispheres. I continue advertising I can't agree with that decision. The light from such bulbs goes in all directions, which is not the case in life. If the light is reflected from the screen, it can not hit the same wall that is located around the screen. You can bring them as close to the screen surface as possible, but then they may overlight it too much. If you reduce the light of the bulbs to a minimum, the reflected light will not come from the screen itself in the correct amount. Which is also unnatural. Try to make a render of your own room, but as if at night, where the light goes reflected only from the screen. Translated with DeepL.com (free version) |
Current timezone is GMT Oct 2, 2026, 12:31:14 PM |
