Print at Oct 4, 2026, 12:05:37 PM
Posted by hansmex at May 27, 2024, 7:49:26 AM
Re: Resize entire project
It's hard to say what you have to do: so many variables, and not much info. Indeed, the AdvancedEditor is the tool to use.
WHAT you have to change depends on what is incorrect. Suggestion: make a backup of your plans and work on that file to see what needs to be done.
1 - check height of levels and thickness of floors
2 - check height of walls
3 - check length of walls
4 - check size of furniture (doors & windows are furniture)
Where it says "check" you should read "check and if necessary correct by multiplying or dividing by 10". When changing furniture make sure you put a checkmark in "Keep proportions".
