Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Moving walls when connected to angled walls » » » » Post: Re: Moving walls when connected to angled walls |
Print at Oct 4, 2026, 4:19:31 PM |
| Posted by lubimaer at May 28, 2024, 6:00:43 PM |
Re: Moving walls when connected to angled walls What you seem to be describing is a CAD style constraint/solver system. SH3D does not have that. Adding that kind of stuff is extremely complex. Indeed, I saw this in other architectural CAD sw I thought this kind of problem were already solved in some free library available in open source I guess this is not the case yet As it's just an angle of 45°, you could try to modify the cooordinates of the wall with its modification dialog, adding or removing the same value to its end coordinates. Keep in mind that you can enter operations in numeric text fields to simplify the maths. Thanks for the suggestion I'll give it a try |
Current timezone is GMT Oct 4, 2026, 4:19:31 PM |
