Sweet Home 3D Forum » List all forums » » Forum: Wishlist » » » Thread: Mark models as favorite (maybe even textures?) » » » » Post: Re: Mark models as favorite (maybe even textures?) |
Print at Sep 30, 2026, 11:09:35 PM |
| Posted by Keet at Jun 2, 2024, 8:26:26 AM |
Re: Mark models as favorite (maybe even textures?) Both favorites and removal of library items can be achieved with workarounds. Favorites (This only works if you have your catalog as a searchable list) Edit the library (or libraries) with the models you want to see as favorites. Add "Favorite" to the keywords list for your favorite models. Import the library and you can use categories like "Doors and windows" like before but when you type "Fav" or "Favorite" in the search bar it will filter only those you have marked as favorite. You can choose whatever keyword you want. '123', 'xyz', or '@@@' will also work as long as it's not a word that is likely to be part of an existing keyword, model name, or description. Be aware that you loose your keyword additions when you import an updated version of a library because that library doesn't have you added keywords. Delete items from Furniture Library You can edit the original library and remove items but you should do that with a renamed copy of the library. Remove the original library and then import your edited library. For textures the same workarounds can be used. ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
Current timezone is GMT Sep 30, 2026, 11:09:35 PM |
