Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: 3D View "Display In Separate Window" Causes Hangs » » » » Post: Re: 3D View "Display In Separate Window" Causes Hangs |
Print at Sep 24, 2026, 1:39:19 AM |
| Posted by dorin at Jun 4, 2024, 4:43:11 PM |
Re: 3D View "Display In Separate Window" Causes Hangs Thanks A.D.STUDIO! I've encountered the same problem even I'm under linux (debian) on both computers (at work and at home). Symptoms: SH3D don't start even with an empty file. Result in konsole: library initialization failed - unable to allocate file descriptor table - out of memorySolution for linux users found on the net: What fixed it was this command as root (su -) (sudo didn't do it): echo >/etc/security/limits.d/systemd.conf "* hard nofile 1048576"Then reboot. Solutions found here and here . I hope it will help someone. ---------------------------------------- A computer program does what you tell it to do, not what you want it to do. Murphy's Law When all else fails, read the instructions. Murphy's Law If you don't like "AS IS", DIY. Dorin's law |
Current timezone is GMT Sep 24, 2026, 1:39:19 AM |
