Sweet Home 3D Forum » List all forums » » Forum: Gallery » » » Thread: Plans for redecoration » » » » Post: Re: Plans for redecoration |
Print at Sep 24, 2026, 7:54:11 AM |
| Posted by Xiste at Jun 5, 2024, 6:31:32 PM |
Re: Plans for redecoration Just testing... Working late ![]() Link to original size image Let me also use this opportunity to say that our new studio is built, and that we eventually got all three floors. This is from the top floor the early process of building a mix stage mix stage, before the windows were hidden behind an acoustically and non-reverberant designed wall. In addition to minimize unwanted reverberation and keep the light out, it is also built with the intention to insulate us from the sounds of the outside world. You can see on the left side that there are already three layer of insulation. When it's finished there will be anotherwal covering that insulation, and the another three layers of insulation behind the final inner wall, which btw will be slightly slanted, to prevent sound waves from bouncing back and forth, which will happen between parallel surfaces. So all the walls will in fact be slightly slanted. With the inner walls in place, the room wil be 4m 90 wide and 10m 80 long. The height will be 3m 84 , which ideally is a bit low. In our last cinema the hight was 5m 96. Link to original image The reason for this testing is that I am about to publish a bigger presentation of how we built our new facility house, illustrated by a combination of renderings and real images, and supply the reader with an easy way to view the original full size images. Xiste |
Current timezone is GMT Sep 24, 2026, 7:54:11 AM |
