Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: 3D View "Display In Separate Window" Causes Hangs » » » » Post: Re: 3D View "Display In Separate Window" Causes Hangs |
Print at Sep 23, 2026, 7:44:59 PM |
| Posted by Puybaret at Jun 6, 2024, 11:23:38 AM |
Re: 3D View "Display In Separate Window" Causes Hangs I was able to reproduce this issue by using the shortcut for Display in separate window / Display in main window menu items (Ctrl + Alt + Y) many times quickly. Andy, is it what you tried on your side? I found it wasn't a memory leak issue, but rather a problem of synchronization between separate / not separate state of the 3D view. Anyway, I fixed it and the correction will be available in the next version. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 23, 2026, 7:44:59 PM |
