Print at Oct 3, 2026, 2:45:24 PM
Posted by sjb007 at Jun 14, 2024, 1:59:52 AM
Re: Disable / Hide objects in plan while showing them in 3d?
Alternative: Create a new level at the same elevation. Put your ceiling objects on this new level, and make sure the level is "above" or after, the level with your furniture. Then select "Display all levels" in your 3D view. Now you can work on your furniture in the plan view without the ceiling objects being in the way. However they will still be displayed in the 3D view. If you have additional levels that you don't want to be visible in the 3D view, you will have to hide those levels - Ctrl+Shift+H is the shortcut for that I think.
