Print at Sep 23, 2026, 4:21:40 PM
Posted by byDMA at Jun 15, 2024, 11:59:25 PM
Re: Dark Mode | Some impressions Beta-1
If under FlatDarkLaf or other LaF don't look OK (columns wide, fonts, borders, icons size etc) I suspect it is the fault of LaF not of the applications.
No. This has nothing to do with FlatLaf at all. Set MetalLookAndFeel again and you will see that it has nothing to do with the topic. This is exactly how it behaves here and there. I don't want to discuss scaling.
1. start with scaling 2x
2. start GR plugin
3. maximize the plugin window
4. then make it smaller again
-> the frames are going through each other. You can no longer set the normal view manually. You have to close the plugin and restart it. Without scaling, this works well and the window gets smaller again and the frames are ok, only the font... you can't see anything ;-)
https://sun9-61.userapi.com/impg/DZvWA-3Q3gxu...5fd70a1307&type=album
