Sweet Home 3D Forum » List all forums » » Forum: Developers » » » Thread: Generate roof plugin » » » » Post: Re: Generate roof plugin |
Print at Sep 24, 2026, 2:16:20 PM |
| Posted by dorin at Jun 20, 2024, 5:15:46 PM |
Re: Generate roof plugin @1. The preview size you've propose could be good. @2. The About button will remain GREEN for my public versions. Some people could receive a customized version. @3. Could be a solution but it is away too wide for other languages. A compromise could be to replace Edges:Slope (Kanten: Neigung) text with only Edges (Kanten). Another solution could be to replace JList with JTable or Jeks and include a header. The invisibility checkbox could be also added for every edge to replace the eye indicator. @4. This setting has not the expected effect. it is a hole file GenerateRoofPluginView.java You've modified few lines: 177, 231, 344(// Need cast int), 346, 421, 422 (//Wrong), 478. For the above lines was enough to make proposal like in patches. For the createUI method it's Ok to post it entirely as you've done in the paste. I hope to not upset you. I'm not a programmer so my opinion don't count too much. ---------------------------------------- A computer program does what you tell it to do, not what you want it to do. Murphy's Law When all else fails, read the instructions. Murphy's Law If you don't like "AS IS", DIY. Dorin's law |
Current timezone is GMT Sep 24, 2026, 2:16:20 PM |
