Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Measure wall length » » » » Post: Re: Measure wall length |
Print at Oct 4, 2026, 10:08:29 AM |
| Posted by dorin at Jun 21, 2024, 2:40:20 PM |
Re: Measure wall length A workaround: 1. Connect the ends of the walls to close a perimeter; 2. Generate a room inside; 3. Use Rooms Information to get the perimeter; ![]() Like this: (in meters) ![]() 4. Select the room and use Edit points from Advanced Editing plugin to find the length between start-end walls. ![]() Subtract 1933 - 299.3 = 1633,7 cm ---------------------------------------- A computer program does what you tell it to do, not what you want it to do. Murphy's Law When all else fails, read the instructions. Murphy's Law If you don't like "AS IS", DIY. Dorin's law |
Current timezone is GMT Oct 4, 2026, 10:08:29 AM |
