Sweet Home 3D Forum » List all forums » » Forum: Gallery » » » Thread: Apartment project with lighting by invisible hemispheres. I continue advertising » » » » Post: Re: Apartment project with lighting by invisible hemispheres. I continue advertising |
Print at Oct 2, 2026, 9:50:54 AM |
| Posted by GaudiGalopin3324 at Jul 1, 2024, 1:49:17 PM |
Re: Apartment project with lighting by invisible hemispheres. I continue advertising now you can open the video editor. You should feel like Steven Spielberg (no less) and think everything through in advance. I decided that the cats would sit on the sink, one inside the bowl, the other outside, part of the front edge of the sink would overlap the front cat. The bath will be filled with water with a video texture of the surface of the shimmering water. Water will not flow out of the upper tropical watering can at the very beginning of the clip. A girl will sit in the bathtub and look at the rain shower. What needs to be done to make all the figures appear as if in the real space of the bathroom? You need to prepare the layers from the SH3D renderer. I made three such layers. the hole for the water in the bathtub (I showed it in black, in fact it is a transparent place), this hole must be made as smoothly and accurately as possible, it will be the edge of visible water, a very important job. the prepared picture with a hole must be saved in PNG format. I marked the most important borders in red, they should be smooth. the second layer needs to be made for the cat and for the girl with the waterfall, this is the front edge of the bowl sink and the front edge of the bathtub. You also need to make these edges very carefully and smoothly, they are important. Other places that do not participate in the contact with the figures can be done less carefully. In the video editor, all the layers will be combined into one whole image without visible borders. I made a long curved hole on purpose to show you that in the end, when you combine the layers, nothing will be visible. ![]() |
Current timezone is GMT Oct 2, 2026, 9:50:54 AM |
