Sweet Home 3D Forum » List all forums » » Forum: Developers » » » Thread: Plugin Development Issue » » » » Post: Re: Plugin Development Issue |
Print at Sep 23, 2026, 5:07:37 PM |
| Posted by dorin at Jul 26, 2024, 10:37:43 AM |
Re: Plugin Development Issue 1. You don't need to de-compile the java class file. In the "Plugin developer's guide", at the end of "Creating the plug-in class" you have a sentences The VolumePlugin plug-in class is now programmed, ... with a link to the java file. You will see the differences between your and the original.2. Continue carefully with the rest of the tutorial especially with the export part where I suggest to check the Export java source files and resources. Here you can change the extension from jar to sh3p but it is not mandatory. The plugin should work even with jar extension. Don't forget to Export the plugin BEFORE every test to see the effects of your modifications. 3. To verify what you've done, start SH3D from a terminal. If something's wrong you will see some messages like The plugin [name_of_plugin] can't be loaded and the reason why. 4. Don't expect to succeed from the first attempt. After you manage to pass this we could continue to help you. PS. I set the eclipse workspace to use the jre1.8 provided by the SH3D. ---------------------------------------- A computer program does what you tell it to do, not what you want it to do. Murphy's Law When all else fails, read the instructions. Murphy's Law If you don't like "AS IS", DIY. Dorin's law |
Current timezone is GMT Sep 23, 2026, 5:07:37 PM |
