Sweet Home 3D Forum » List all forums » » Forum: 3D models and textures » » » Thread: Problem with modified invisible inward light half sphere » » » » Post: Re: Problem with modified invisible inward light half sphere |
Print at Oct 2, 2026, 6:59:40 PM |
| Posted by Puybaret at Jul 31, 2024, 3:40:28 PM |
Re: Problem with modified invisible inward light half sphere About the size, the reason could come from the fact that you imported the OBJ file or the ZIP file containing the OBJ+MTL file. When you import a ZIP file, it is saved as is in the SH3D or SH3F file, whereas when you import a OBJ file, it's internaly exported then reimported leading to higher files at the end, containing normals and only triangles. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Oct 2, 2026, 6:59:40 PM |
