Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: Colors and texture change after 3D picture » » » » Post: Re: Colors and texture change after 3D picture |
Print at Sep 28, 2026, 1:31:59 PM |
| Posted by sjb007 at Aug 24, 2024, 2:58:51 PM |
Re: Colors and texture change after 3D picture If you want the image to look like the "correct version" you need to turn the "Kwaliteit" down. That gives you renderings that look like the 3D viewport rendering. If you just want to make your "bad picture" brighter but keep the more natural rendering then you could start by moving the time and date to a time when the sun higher in the sky. At 8:00 am the sun is still low, hence the lower light. Put it to noon, and change the date to 21 June (Summer Solstice) and the sun will be as high as possible overhead, and it will give a much brighter result. |
Current timezone is GMT Sep 28, 2026, 1:31:59 PM |
