Print at Sep 24, 2026, 12:50:00 AM
Posted by Keet at Aug 26, 2024, 7:57:54 PM
Re: Turning off shadows
You can't turn off shadows. Light and shadows are inheritant to photo rendering. That's why you can set the parameters Hans mentioned.
The tips Hans gave you placed the sun exactly above your project which should get rid of most of the (side way) shadows.
Basically, to have no shadows you have to have no light. It is what photo rendering does. The closest you can come to no shadows is to carefully compensate every shadow with counter-lights without creating new shadows. Placing lights to neutralize shadows. That doesn't mean there are no shadows, just that you diffused them with more light.
You can also try to set the time to midnight so there's no outside sunlight and un-check "Add ceiling lights". Than use multiple "Invisible inward light half sphere" objects to light the room.
Check out this thread from GaudiGalopin3324 who is an expert in using these objects to lighten rooms and furniture. It's a very long thread but you can learn a lot about using light sources.
