Sweet Home 3D Forum » List all forums » » Forum: New versions » » » Thread: Wirings plugin » » » » Post: Re: Wirings plugin |
Print at Sep 23, 2026, 10:36:39 AM |
| Posted by amic at Aug 28, 2024, 7:55:58 AM |
Re: Wirings plugin Dear Daniele, thanks a lot for your plugin. I was initially struggling a lot to get it working, I could only use the automatic wiring function (and the pan was not working). And finally, reading all this thread meticulously, I found someone with the same trouble as me. Switching to openjdk-8 was the solution (even at the start of sweethome3d, it seems that the greeting window has changed size). So thanks for all the work ! I guess it would be very interesting to write that as a warning regarding the requirements. If I manage to find some time, I would be interested in contributing to the french translation, which is quite cumbersome at the moments, for instance ”wiring” is translated « plantes » which has really nothing to do ;-). Could you tell me where I could help you for that ? |
Current timezone is GMT Sep 23, 2026, 10:36:39 AM |
