Print at Sep 28, 2026, 7:35:11 PM
Posted by Keet at Sep 6, 2024, 7:12:39 AM
Re: Holes with curves in curved surfaces
The object list has more uses: you can select multiple objects with click and drag up or down in the list. With the correct ordering this is often more efficient than selecting in the 2D pane. Just remember that multi select with individual clicks in the 2D and 3D panes is with the shift key and in the object list with the ctrl key.
Without any ordering (no arrows in any of the column headers) new objects are added to the bottom of the list. This will not only show you the order in which the objects were added but it makes it easy to find a new added object in a long list: at the bottom.
Another very important feature is that you can add objects to an existing group by copying an object, then select the group in the list and right click for the context menu, select "Paste to group".
