Print at Oct 3, 2026, 3:13:00 AM
Posted by Keet at Sep 6, 2024, 6:54:05 PM
Re: Dodecagon
Your misalignment with the dishwasher looks like a difference in elevation. Both cabinets and dishwasher should have elevation 0.
If you don't use side-by-side alignment, at least align them at the top.
Same with the 30cm drawers cabinet. Using side-by-side or top alignment I get it perfect.
To be perfecty clear: put cabinets and dishwasher roughly next to each other. No need to touch or align, just in the correct order you want them. select them all and then use align side-by-side from the context menu. The result should be that all tops are aligned and perfectly against each other.
