Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: How do I slide a wall exactly in SH3D Windows? » » » » Post: Re: How do I slide a wall exactly in SH3D Windows? |
Print at Sep 29, 2026, 8:35:04 AM |
| Posted by Keet at Sep 11, 2024, 7:19:24 PM |
Re: How do I slide a wall exactly in SH3D Windows? There are several ways. What I mostly use: 1. Select a wall and move it with the cursor keys. The size of movement depends on the zoom level. Fully zoomed in it's 1mm per key press, the smallest possible in Sweet Home 3D. I don't know what the value is if you have your system set to imperial. 2. change the X/Y location coordinates of the start and end points of the wall in the Modify Wall dialog. 3. Use the move function of the advanced edit plugin. Select the wall and in the move dialog set the value to move. It will immediately show in the plan and if you cancel it it will revert to the original position. Method 2 can set a precise position. Method 3 can move with precision counting from the start position. ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
Current timezone is GMT Sep 29, 2026, 8:35:04 AM |
