Print at Oct 2, 2026, 5:31:38 AM
Posted by db4tech at Jun 14, 2010, 2:28:18 PM
Re: Option to replace furniture
Hi All!
I have read over the blog and let me see if I understand the dialog. db4tech, you wish for standard regulation size furniture and walls? Is this correct?
If so, Puybaret, this does in fact speak to the creation of standard pieces and functions that will support the learning of proportions and scale.
Hi manna4ang,
Firstly welcome to the forum.
In answer to your question, both yes and no smile you see almost all the furniture that is available on the download page (if it is in a multiple furniture package) is already to the correct scale when used in the plan, only separate imported (OBJ, DAE, 3DS plus others) furniture and objects need to be scaled correctly on import.
Your point is valid too though. It is mainly a good base wall thickness I thought would be most helpful, especially for new users.
db4tech
