Sweet Home 3D Forum » List all forums » » Forum: Gallery » » » Thread: Dodecagon » » » » Post: Re: Dodecagon |
Print at Oct 2, 2026, 8:30:42 PM |
| Posted by Keet at Sep 23, 2024, 7:17:36 AM |
Re: Dodecagon I put one of each door in my project, but all had that odd square knob on the inside side of the door. I've never seen something like this... Maybe it's more common where you’re from. The square handle is the outside of the door and yes, that's common here. From the outside you unlock the door with a key and push the door inside or use the handle to pull the door closed when you go out. On the inside you have a normal handle to open the door without a key.The square outside handle could just as easy be a round knob but here they usually don't turn to open a door. The same on the inside would turn to open. Have you thought about making the square handle invisible and add your own knob? In the obj file of the knob just give each group the prefix "sweethome3d_opening_on_hinge_1_". Import the knob and add it to the door. Export/Import door+knob and you have your door with your own knob. Good job with the dishwasher in the corner. Looks quite nice! ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
Current timezone is GMT Oct 2, 2026, 8:30:42 PM |
