Print at Oct 3, 2026, 12:56:42 AM
Posted by Daniels118 at Oct 16, 2024, 6:47:01 AM
Re: SOLVED: Non-square textures on non-square faces
Here is another solution. You may have already found that tiling works perfectly when the texture is applied to a wall or floor (room). You may model your shelves using walls or rooms, and then export them as obj and import them back as furniture.
