Print at Oct 6, 2026, 1:03:00 AM
Posted by Puybaret at Jun 18, 2010, 5:10:03 PM
Re: Increase memory
I don't know the criterion that could help me determine whether it would work or not. I didn't find a Java bug that would match the problem.
If the bug is bound to the total memory available on the computer, your idea to set the value of -Xmx at program startup is nice, except that it could work only with the version running with the installer and not with applets or with Java Web Start. And in the version with installer it wouldn't be easy to program (it can't be done in Java).
I presume it doesn't make speed difference with Uber shader probably because this kind of shader requires more memory.
