Sweet Home 3D Forum » List all forums » » Forum: New versions » » » Thread: Wirings plugin » » » » Post: Polylines have wrong width in 3D view |
Print at Sep 23, 2026, 10:36:28 AM |
| Posted by ned14 at Oct 23, 2024, 2:50:28 PM |
Polylines have wrong width in 3D view I'm drawing in a ventilation duct and I'm finding that the Wiring polylines have the wrong width in the 3D view. Here's a screenshot: ![]() I'm making this by creating little cylinders of the correct diameter everywhere there is a bend, then using the auto-wire feature to create wiring between those points. It's clunky, but it does work. (Incidentally, if I could draw the ducts as polylines, then ask the Wiring plugin to import them as wire, that would be a great feature) In the screenshot above, I made one of the wires the correct width, which is 205 mm so it matches the diameter of the cylinder fragments. This shows correctly in the 2D view, but it is clearly far too thin in the 3D view. If I create a polyline manually, it shows the correct width in both 2D and 3D. Is this a bug in the Wiring plugin? Am I doing something wrong? Other features which would be great to have is rendering the wires as cylinders instead of polylines so they gain thickness. I have some three phase cable which will be quite thick, also I have water pipe. Thanks for your plugin. It's a killer feature, I can't find anything anything else like it which doesn't cost thousands of euro per year in licensing fees. Niall |
Current timezone is GMT Sep 23, 2026, 10:36:28 AM |
