Sweet Home 3D Forum » List all forums » » Forum: Gallery » » » Thread: mirror prefixes » » » » Post: Re: mirror prefixes |
Print at Oct 3, 2026, 6:32:16 PM |
| Posted by Keet at Oct 29, 2024, 7:57:13 AM |
Re: mirror prefixes There are three prefixes with different names that should create a mirror effect on the surface of the models. Note that these are basically the same. 1.... sweethome3d_window_mirror 2.... sweethome3d_window_mirror_on_hinge_ 3.... sweethome3d_window_mirror_on_rail_ ⚫ sweethome3d_window_mirror creates a mirror effect, ⚫ _on_hinge / _on_rail attaches the mirror to a deformation. ⚫ _on_hinge / _on_rail do not change the effect of sweethome3d_window_mirror. ⚫ sweethome3d_window_mirror_on_hinge_ is a shorthand for the non-existing sweethome3d_window_mirror_and_sweethome3d_opening_on_hinge_ ⚫ sweethome3d_window_mirror_on_rail_ is a shorthand for the non-existing sweethome3d_window_mirror_and_sweethome3d_opening_on_rail_ For experimenting with the mirror you don't need the deformations since deformations (duh!) don't work on a photo. It can be an easy way to create a series of photos with the mirror in different positions. For example with a bathroom cabinet mirror door that is opened in different positions for each consecutive photo. You can then use the series of rendered photo's to create an animated GIF. ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
Current timezone is GMT Oct 3, 2026, 6:32:16 PM |
