Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: (Semi)transparent Mirrors » » » » Post: Re: (Semi)transparent Mirrors |
Print at Oct 2, 2026, 2:33:09 PM |
| Posted by scjo at Oct 30, 2024, 10:51:11 PM |
Re: (Semi)transparent Mirrors It works: ![]() The mirror is 70% transparent. You may try different transparencies using the source images. With Image Magick installed, compositing is a simple command: composite mirror-opaque.png -blend 70% mirror-off.png mirror-semi.pngIn reality, the scene behind the mirror would be quite dim, and the transparency much lower, maybe 15%. That makes it harder to look through from the front and accommodates the observer behind to the little amount of passing light. The mirror leans 1° away from us. Therefore the mirrored horizon is 2° below the one in direct view. ---------------------------------------- Cheers - Joe // |
Current timezone is GMT Oct 2, 2026, 2:33:09 PM |
