Sweet Home 3D Forum » List all forums » » Forum: 3D models and textures » » » Thread: Splash Pad model for outdoor yard » » » » Post: Re: Splash Pad model for outdoor yard |
Print at Oct 2, 2026, 8:46:57 AM |
| Posted by GaudiGalopin3324 at Nov 20, 2024, 12:25:50 PM |
Re: Splash Pad model for outdoor yard Hi. This rug can be made by yourself. You need to find a picture of the "dog's footprint in a circle" in the search. Make it a background image on the plan, set the size of the circle, for example, 300 cm.Then you need to start making a room based on this drawing. Start from point 1, go to point 2, carefully outline the area through small distances to point 3, go to point 4, outline everything around the perimeter and return to point 3, outline to point 5, then to 6 and so on. The main thing is not to be afraid!!))) And don't stop. The most recent action is to complete the outer circle, reach point 1 and double-click. The room is ready! It will take about 15 minutes with moderate care. The neater the longer)) when creating a room, you need to turn off the magnet. Then you need to turn this room into a rug with a thickness of for example 3 cm. You need to set the overlap thickness of 3cm in the settings and create a new level, you will get a 3cm thick mat. You need to import this room into OBJ, then export it back as a model and give it a name, assign a color or texture. Add dogs, fountains. Try to do it yourself, it's very exciting. And most importantly, you will be able to get exactly what you need. ![]() |
Current timezone is GMT Oct 2, 2026, 8:46:57 AM |
