Print at Sep 23, 2026, 1:09:50 PM
Posted by Puybaret at Dec 14, 2024, 12:41:35 PM
Re: Export to HTML5 plug-in
@vlycop
You must use a plug-in which uses some data that the plug-in may not be able to handle.
@Keet
In project SweetHome3DJS, you should remove the lines 375 to 391 in build.xml and run Ant viewerBuild target.
