Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: massive color-difference » » » » Post: Re: massive color-difference |
Print at Oct 11, 2026, 4:55:44 AM |
| Posted by c0d3z3r0 at Dec 27, 2024, 8:40:17 PM |
Re: massive color-difference The problem seems to be that Java3D expects Linear RGB as input color space:https://forum.jogamp.org/sRGB-and-gamma-correction-in-Java3d-td4038946.html I've tested this by manually setting the RGB value of a wall to a gamma-corrected value ( lin=255*(val/255, 2.2) ), which makes yafaray and sunflow output the correct color. There are two options: 1) feed in a generated texture or 2) convert the colors to linear RGB |
Current timezone is GMT Oct 11, 2026, 4:55:44 AM |
