Sweet Home 3D Forum » List all forums » » Forum: New versions » » » Thread: Terrain Generator plug-in » » » » Post: Re: Terrain Generator plug-in |
Print at Sep 23, 2026, 10:37:25 AM |
| Posted by c0d3z3r0 at Dec 30, 2024, 3:39:21 PM |
Re: Terrain Generator plug-in Hi, thanks for this great plugin! Is there anyone else having problems with levels below 0, where the terrain will be shown higher than it should be? I tried to fix this in the code but miserably failed :D To me it looks like negative elevation is being ignored / set to 0. Oops, the problem is also present in higher levels and the reason is that the plugin always uses 0 as base instead of the current level's elevation. |
Current timezone is GMT Sep 23, 2026, 10:37:25 AM |
