Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Fireplace lightning » » » » Post: Re: Fireplace lightning |
Print at Oct 2, 2026, 5:23:09 AM |
| Posted by Keet at Jan 8, 2025, 7:15:08 PM |
Re: Fireplace lightning You know any animated gifs for it? Search images for "animated gif fire", you will find dozens too choose from.You mean apply in sweet home? and then what? how will it move in HA? You apply the gif just like any other texture and export it the same as you did with you current fireplace. Import in Home Assistent is also the same as you did before. Even though Sweet Home 3D doesn't display the animation it does export the gif as-is, meaning that your export still has an animated gif. Home Assist should show it. Make sure the gif is copied along with the obj and mtl files. Always keep the obj, mtl, and texture images together. If Home Assist can handle a zip file you can create a zip with the obj, mtl, and gif. ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
Current timezone is GMT Oct 2, 2026, 5:23:09 AM |
