Print at Oct 3, 2026, 1:24:24 AM
Posted by GaudiGalopin3324 at Jan 9, 2025, 6:56:24 AM
Re: Fireplace lightning
I didn't succeed(. Replacing a JPG texture with a GIF does not produce live fire. There is a new image on the model, but without movement. Can you show the result using a simple example with a GIF texture? What needs to be done? I inserted a GIF image into the ZIP file and nothing happened (although it was exported to the SH library as a live texture with movement, I see it there as a live fire). In the second case, I replaced the JPG with this GIF image. There is still no movement... What am I doing wrong? confused
