Print at Oct 2, 2026, 5:21:06 AM
Posted by MarioSambol at Jan 17, 2025, 10:28:27 PM
Re: import 3d model to unreal engine
I just tried importing a test file into Unreal engine 5.4.2 and everything works as it should. I only added the asset name, and it has to be imported as a single object. Otherwise, the same problem occurs when importing into 3DS max. If I import as a separate object, it doesn't work. If I import as a single object, it works. From Sweet home 3d, I exported only the selection.
