Sweet Home 3D Forum » List all forums » » Forum: Gallery » » » Thread: A way to make any model in the correct sizes » » » » Post: Re: A way to make any model in the correct sizes |
Print at Sep 28, 2026, 1:19:37 PM |
| Posted by GaudiGalopin3324 at Jan 24, 2025, 7:32:38 AM |
Re: A way to make any model in the correct sizes Now for the more complicated case. Bed. Often the bed model is complemented by a headboard, bedside tables, it has pillows, a blanket hangs on the floor. All this makes the model incomprehensible in size. But there is an important element to the bed. It's a mattress. All mattresses are standardized. the width of the mattress for a single bed is 90 or 100 cm, the length is 200 cm. For a double bed, these are sizes 140-160-180-200 cm. The length is also 200cm. Download the model, keep the proportions and set the height of the backrest to 70cm, which is usually much lower than the bed in reality. Now make a bright-colored mattress template. I made 180x200 cm, height 55cm. This is the usual standard height of the mattress in the bed, but I advise you to measure your bed with a tape measure at home, this will convince you of the truthfulness of the height. She may be a little different, trust her. Now stretch the model by the corner so that the bright template fits into place, but sticks up out of the bed, align the bed and the template, to do this, turn off the magnet. Now select the bed model and stretch it up so that the mattress template starts to be covered with the model's blanket. This will be the correct proportion of the bed inside a complex model. Remove the template and you're done. You can put a model of a girl on such a bed, make a height of 130 cm for her, keeping the proportions. She will push through the bed a little, this is how it will be in reality, she will sit a little deeper. The girl's model can be rotated slightly on the X-axis if it turns out completely without hands. I turned 10 degrees so that my fingers appeared on the bedspread. ![]() |
Current timezone is GMT Sep 28, 2026, 1:19:37 PM |
