Print at Sep 23, 2026, 10:40:03 AM
Posted by dorin at Feb 3, 2025, 6:08:06 PM
Re: Staircase generator plug-in
Could someone verify this?
With this input data:
I have this output for cut out shape
I suppose the problem is between lines 1149~1156
} else if (spiralStaircaseAngle <= Math.PI) {
float width = (1 - cosAngle) * spiralStairOuterRadius;
float height = spiralStairOuterRadius + treadDelta;
cutOutShape = "M 1," + (height - treadDelta) / height
+ " A " + spiralStairOuterRadius / width + "," + (height - treadDelta) / height + " 1 0,0 0," + (1 - sinAngle)
+ " L " + cosAngle * (spiralStairInnerRadius - spiralStairOuterRadius) / width + "," + (spiralStairOuterRadius - sinAngle * spiralStairInnerRadius) / height
+ " A " + spiralStairInnerRadius / width + "," + spiralStairInnerRadius / height + " 1 0,1 "
+ -cosAngle * (spiralStairOuterRadius + spiralStairInnerRadius) / width + "," + (height - treadDelta) / height
+ " z";
It happened only in this range 90~180 degrees with inner radius > half pole.
As you can see there is a lot of math which I don't know.
Any opinion (or help) is highly appreciated.
Thanks in advance!
