Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Multiple sloped wall with window » » » » Post: Re: Multiple sloped wall with window |
Print at Oct 2, 2026, 5:11:09 AM |
| Posted by Keet at Feb 6, 2025, 7:43:28 PM |
Re: Multiple sloped wall with window Situations with these kinds of sloping walls are unique for each project. There is no generic solution for this, usually the slope is the bottom/underside of the roof you add. If you want the slope independent of the roof you can use a thin box that you tilt and elevate. A thin box can close a sloping space without sticking out on the outside. Make all sides of the box invisible except the one that you see as the slope. You can also use a triangle and make all sides except the slope invisible. Rotate and elevate as needed. The effect is the same as with a box. ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
Current timezone is GMT Oct 2, 2026, 5:11:09 AM |
