Print at Sep 29, 2026, 8:29:25 AM
Posted by dorin at Feb 9, 2025, 7:07:56 AM
Re: Changing coordinate reference of object to its corner
If I correctly understood the question:
1. The lumber is better to be as furniture to be more easy manipulated.
2. Probably you need many lumbers aligned at same distance or distributed evenly.
3. If this is the case SH3D have at least 8 way under Align or distribute furniture contextual menu.
For distribute you have to set the precise position of the first and the last piece, then select all, right click and chose Distribute horizontally.
4. Supposing the lumbers is the same, the distance between left corners is the same with distance between centers. You need it once.
Knowing this you could use Multiplier plugin made especially for this kind of task.
