Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Copy saved view » » » » Post: Re: Copy saved view |
Print at Oct 2, 2026, 12:42:01 PM |
| Posted by Keet at Feb 15, 2025, 2:42:27 PM |
Re: Copy saved view For me (on Linux) it works as I decribed. I use the same method to update version numbers in furniture library property files (a furniture library .sh3f file is also a zip file). You can first try to rename the .sh3d to .zip. Maybe that solves the readonly problem if you are sure the file is not readonly. Maybe it's in a directory where you can't edit? If that doesn't work then you can extract the whole file in a directory. Update and save the Home.xml file. Select all files in the directory and create a new zip file. Change the extension from zip to .sh3d and you're done. ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
Current timezone is GMT Oct 2, 2026, 12:42:01 PM |
